Showing results forĀ
Search instead forĀ
Did you mean:Ā
Battery drain
(Topic created: 10-07-2021 06:49 AM)
userQZDOI3Omv6
Discussions
Battery drain is 4-5 times more than normal.
userQZDOI3Omv6
Discussions
Especially during nights
Nick515
Cosmic Ray
Discussions
Battery drain when the screen is off is worse with Beta2
Discussions
Did any of you guys do a hard reset? I had a few issues on beta 1 like battery drain,secure folder not opening, etc ,etc, and finally I did a backup and did a hard reset while on beta 1and I'm not experiencing any issues at all. Maybe a very slight lag here and there but nothing to complain about. I know reseting could be a pain especially if you have a ton of apps and then having to put your phone back the way you had it set up but sometimes it's worth the trouble.
user751201tmO21
Honored Contributor
Discussions
Battery was okay during beta1, but with beta2, battery drain has gotten worse.
Ihr7
Cosmic Ray
Discussions
Literally same šŸ’”
USBetaModerator
Beta Moderator
Discussions
Hello @userQZDOI3Omv6 ,
Thank you for your feedback. If you havenā€™t already, Please update Samsung members app to latest version from galaxy store and send us an error report immediately after experiencing the issue from the Samsung memberā€™s app -> Beta Feedback -> Error Reports to help us debug the issue. We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards,
One UI Beta Team
