Battery drain
(Topic created: 10-23-2021 09:19 AM)
Karnage
Galaxy
Discussions
I just noticed the battery drains faster on beta 3 then it did on beta 2 foe some reason, I am on the Galaxy S21 Ultra
user751201tmO21
Honored Contributor
Discussions
21 Ultra Unlocked here.
Beta1 battery life was somewhat normal.
Beta2, battery life got worse.
Beta3, battery life has increased - maybe not where I'd like it to be, but it's close.
MochaVex
Supernova
Discussions
Not nearly as bad as Beta 2 on my end. Went from 15% per hour of screen time down to about 12%
Beta 1 was below 9% and I'd like it to be that efficient again someday
Discussions
Idk..it's gotten a whole lot better for me so far.. 10% after an hour use with wifi... I was losing that 10% after 20 minutes of use on beta 2.. lol
Mello_o
Nebula
Discussions
Yes, mine is better than Beta2. The Beta 3 is so perfect
USBetaModerator
Beta Moderator
Discussions
Hello @Karnage ,
Please erase the device cache using steps below. If issue persists, Please update Samsung members app to latest version from galaxy store and send us an error report from the Samsung member’s app -> Beta Feedback -> Error Reports to help us debug the issue.
  1. Turn off the device.
  2. Press and hold the Volume Up key and the Side key.
  3. When the Android logo displays, release both keys.
  4. An 'Installing system update' message may show briefly before the Android Recovery menu options appear.
  5. Press the Volume down key several times to highlight Wipe cache partition.
  6. Press Side key to select.
  7. Press the Volume down key to highlight Yes, then press the Side key to select.
  8. When the process is complete, Reboot system now is highlighted.
  9. Press the Side key to restart the device.
Regards,
One UI Beta Team
