Battery drain?
(Topic created: 12-08-2024 11:43 AM)
Discussions
Has anyone bring having a major battery drain recently with the beta? And has anyone figured out if it's the actual Beta or an app that is draining the battery
Daisymone
Halo
Discussions
Yeah I feel like it's been draining for me as well.
Nurse2talk2
Cosmic Ray
Discussions
Yes, faster drain
Clayface
Discussions
Yes I'm feeling like I'm charging my phone frequently than normal.
Y0u
Honored Contributor
Discussions
Did you clear the cache partition
Discussions
What cache partition?
I can definitely try it if you tell me where to look!
TRAV248
Cosmic Ray
Discussions
Power the phone off completely.
Press and hold the Power + Vol Up button until you see a menu. Use the Vol Down button to get to the wipe cache partition. Wipe the cache 6x.
Use the Vol Up button to scroll back up to reboot and that's it.
You can also do a proper factory reset from this Recovery Menu. Don't worry you cannot brick or mess your phone up doing this.
Discussions
Why 6x? Just wondering
Y0u
Honored Contributor
Discussions
I sometimes do 8x
TRAV248
Cosmic Ray
Discussions
No reason. Just to make sure it's cleared. LoL.
