Battery drain?
(Topic created: 12-08-2024 11:43 AM)
Discussions
Has anyone bring having a major battery drain recently with the beta? And has anyone figured out if it's the actual Beta or an app that is draining the battery
Discussions
I'm gonna hold off this second it seems ok I did change my screen resolution from top quality to the middle setting and played around with some of the battery options it seems my insurance app was randomly using power even though I haven't opened it in over a month
TRAV248
Cosmic Ray
Discussions
I haven't noticed it. However, I did a fresh install after doing a factory reset.
Kett
Cosmic Ray
Discussions
Yes, my battery drain really fast
shannon09
Discussions
I am experiencing a faster battery drain as well.
RedOregon
Sun
Discussions
When thinking about battery drain, don't forget to take into account extra time you might be spending digging through all the new settings, options, etc.
user9vIyeYTWWZ
Discussions
Yes, absolutely.
USBetaModerator3
Beta Moderator
Discussions
Hello @Nikolas1227 ,
Thank you for your feedback on battery draining.
To assist us in resolving this issue, we kindly ask you to submit an error report through the Samsung Members app on your device:
1. Open Samsung Members.
2. Navigate to One UI Beta Program > Beta Feedback.
3. Attach any relevant screenshots (if possible).
4. Ensure "Send system log data" is checked, then submit the report.
Important: Please submit the report within 15 minutes of reproducing the issue for accurate log data collection.
We sincerely apologize for any inconvenience this may have caused and truly appreciate your contribution to improving the Beta experience.
Best regards,
One UI Beta Team
Discussions
I already did thank you
