Battery drain
(Topic created: 05-28-2026 07:09 AM)
Shaurya
Discussions
The battery is draining rapidly just in 3 hours with no use it went down 50%. And the phone is getting hot with minimum use
PeninaD
Comet
Discussions
Wow, I am not experiencing that, thankfully
StickyDonkey
Cosmic Ray
Discussions
Double check that you don't have any of the Debugging enabled in Developer options. I did and it was killing my battery. It's off by default obviously, so only if you may have enabled it at some point and forgot to turn it off like I did.
DD7227
Galaxy
Discussions
Just asking but have you:
1. Rebooted since updating?
2. Checked to see if or what could possible be draining your battery by running in the background?
CoreyDeane76
Comet
Discussions
Mine seems to be fine.
Y0u
Honored Contributor
Discussions
You can also download thermal guardians from the good guardians app, to see why your phone is running hot1779984723680.jpg
user2QCKBSuh7L
Discussions
Mine seems fine too
USBetaModerator3
Beta Moderator
Discussions
Hello,
Weโ€™re sorry for the inconvenience youโ€™re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members โ†’ One UI Beta Program โ†’ Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure โ€œSend system log dataโ€ is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
