Beta 2 Battery Drain
(Topic created: 12-23-2024 07:00 AM)
userlQcCM1wRc8
Black Hole
Discussions
It's beta!
Yes, I reported to Samsung.
Many others have posted and hope they are reporting as well.
Look forward to the fixes.
They will come.
In the meantime, watching my battery go down... down... down 😂
Merry Christmas to all! 🎄 🎁
USBetaModerator3
Beta Moderator
Discussions
Hello,
Thank you for your feedback.
To assist us in resolving this issue, we kindly ask you to submit an error report through the Samsung Members app on your device:
1. Open Samsung Members.
2. Navigate to One UI Beta Program > Beta Feedback.
3. Attach any relevant screenshots (if possible).
4. Ensure "Send system log data" is checked, then submit the report.
Important: Please submit the report within 15 minutes of reproducing the issue for accurate log data collection.
We sincerely apologize for any inconvenience this may have caused and truly appreciate your contribution to improving the Beta experience.
Best regards,
One UI Beta Team
Garby
Discussions
I got the same thing
DD7227
Galaxy
Discussions
Battery drain is common during beta testing. They'll fix it.
userlQcCM1wRc8
Black Hole
Discussions
Yes, I know.. That's what I said. My post was a reminder to send feedback to Samsung and not just drop comments. As it is common in the beta, they are aware, I'm sure, but still valuable send fedledback.
Discussions
I did that about the battery icon being changed so I think if everyone did that we would see results. And I mean about anything they want to see improved. I don't notice my battery draining more, it actually seems to have improved and lasts longer but I definitely recommend people do that for any issue they are having!
userJAs42KPtET
Cosmic Ray
Discussions
If you clear cache partition after update, battery drain isn't near as bad. Or at least that's what works for me.
LV2CO
Discussions
How or where do I go to do this?
userJAs42KPtET
Cosmic Ray
Discussions
Turn your phone off for a minute. When you turn it back on, push and hold the power button and the volume up button at the same time till a menu pops up. Scroll down using the volume key and select clear cache and then reboot. If you Google clear cache partition on Android it will give you directions as well.
USBetaModerator3
Beta Moderator
Discussions
Hello,
Best regards,
One UI Beta Team
tomwhysy
Cosmic Ray
Discussions
I noticed higher battery usage as well it dropped from 65%÷ to high 40ish% after full day at work and my usage didnt change , phone setting was on power saver
