Battery drain
(Topic created: 12-24-2024 03:43 PM)
Cambridge Court
Discussions
After the second Beta download the battery has started dragging very fast.
USBetaModerator3
Beta Moderator
Discussions
Hello,
Thank you for your feedback.
We appreciate your contribution to the Beta community.
Regards,
One UI Beta Team
wackywood82
Cosmic Ray
Discussions
Yes mine as well
Y0u
Honored Contributor
Discussions
Have you tried clearing the cache partition and run galaxy booster from good guardians and report this issue to samsung, so they can see what's eating the battery
Discussions
Mine is fine. It actually lasts full day with moderate to heavy use
USBetaModerator3
Beta Moderator
Discussions
Hello,
Regards,
One UI Beta Team
Discussions
FWIW, I'm not experiencing any real battery drain issues with beta 2.
Discussions
Galvanized718
Cosmic Ray
Discussions
Mine feels like it goes down way too fast also.
