Excessive Battery Drain with QHD+ On
(Topic created: 03-17-2025 09:53 AM)
Not applicable
Discussions
Is anyone experiencing much more battery drain with QHD+ than FHD+? I know it's going to consume more battery but it's significantly more.
Youu
Honored Contributor
Discussions
Same
JG94
Nebula
Discussions
I just leave mine on FHD. You literally can't even tell the difference between the two
Discussions
I can tell a huge difference.
JG94
Nebula
Discussions
Lol if you insist
Stereo386
Comet
Discussions
If the screen was smaller than 1080p wouldn't be too bad due to the pixel density, but on this big bad-boy of a screen 2K resolution is a must, at least for me. I don't notice a big drain difference thou. That is strange. Turn it on to 2k resolution, and as soon as you notice its doing the battery drain, then send out an error- log through this teams app, and describe the issue to the devs. I hope that helps a bit at least.
Not applicable
Discussions
Thank you. I restarted my phone and it seemed to have helped a bit.
USBetaModerator3
Beta Moderator
Discussions
Hello,
Thank you for sharing your valuable feedback with us. We truly appreciate the time and effort youโ€™ve taken to contribute to the One UI Beta community.
Your input is essential in helping us identify areas where we can improve and refine the One UI experience.
If you haven't already done so, please kindly submit an error report to help us analyze the observations more in detail.
Weโ€™re grateful for your active participation and support in shaping the future of One UI. Please feel free to share any additional insights or suggestions you might have.
Regards,
One UI Beta Team
userYaJJmQIBit
Discussions
I am experiencing the battery drain after Beta 5 update.
