Gaxaly S22 1UI Beta Battery Drain
(Topic created: 08-07-2022 01:54 PM)
Tony183
Discussions
I'm experiencing very high battery drain. Is anyone else out there with the same issue?
egor0128
Comet
Discussions
I am so sorry to hear that so far this has been the best version I have seen yet. Good luck out there
Discussions
I wouldn't say mine is draining, but for me it's definitely not as good as before
bluefire
Comet
Discussions
Do a clar system cache and go to battery settings to see if an app is missbehaving/crashing causing the battery drain
Yamialex224
Honored Contributor
Discussions
My battery seems to be better on my s22 plus
kev35
Cosmic Ray
Discussions
Yep it's draining fast
Ryan891
Supernova
Discussions
My battery has actually been way better than before . Did you try clearing cache and repairing apps with the Good Guardians App booster?
userEO5ixYznce
Discussions
I'm having issues with the Nearby Service app draining my battery. 40% battery. 2nd worse app is only 3%.
lawyerdude
Cosmic Ray
Discussions
Mine is draining too
USBetaModerator2
Beta Moderator
Discussions
Hello,
Please try the suggestions made by other users in this post.  If the issue persists, please send us an error report from the Samsung member’s app -> Beta Feedback -> Error Reports. We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards,
One UI Beta Team
