Smart suggestions draining battery
(Topic created: 10-01-2022 06:01 AM)
Discussions
Noticed that was the reason of my sudden battery drain issue and turned it of about 2 hours ago , 5 minutes ago i checked the baterry stats and it still shows smart suggestions even tho i turned it off ( before i turned off it was at 7% and now is at 11%)
This is ridiculous i charge my battery to 95% and smart suggestions is draining 35% of that.
KBWolf
Nebula
Discussions
Yea I had this issue as well. What I found out that worked is going to
Settings > Apps > Show system apps > Smart suggestion > storage > Clear data
Try that out and see how it goes
Discussions
I turned on and off again , restart my phone about 20 minutes ago , and so far it hasnt increase if i see it increasing the battery usage again i will try what you said and will update, thanks
USBetaModerator2
Beta Moderator
Discussions
Hello ,
Thank you for your feedback.
If you haven’t already, Please update Samsung Members app to latest version from the Galaxy store and send us an error report immediately after experiencing the issue from the Samsung member’s app -> Beta Feedback -> Error Reports to help us debug the issue.
We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards,
One UI Beta Team
