Volume Sound output indicator
(Topic created: 06-08-2026 05:39 PM)
userWKIEab4y8z
Discussions
Anyone else getting a bluetooth symbol at the bottom of the volume slider after pressing a volume button. I have no audio Bluetooth devices connected and it shows that icon.
Shahpour
Galaxy
Discussions
There was an update to Sound assistant couple weeks ago that fixed that
Y0u
Honored Contributor
Discussions
The recent update fixed this, have you updated sound assistant
USBetaModerator3
Beta Moderator
Discussions
Hello,
We’re sorry for the inconvenience you’re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members → One UI Beta Program → Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure “Send system log data” is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
