Air Command does not work.
(Topic created: 07-30-2025 05:09 PM)
DanielGuzmanBanos
Cosmic Ray
Questions
With the new software installed today the air command stopped, any solution for this.
Y0u
Honored Contributor
Questions
If you have pentastic installed, if you uninstall it should work fine
JesterPizzle
Comet
Questions
That worked for me. Thank you. I wish I could mark your response as a resolution but it's only giving me the option to report your post. Oh well. Guess we'll have to wait for the next update.
Y0u
Honored Contributor
Questions
Np glad I could help
USBetaModerator3
Beta Moderator
Questions
Hello,
Thank you very much for sharing your feedback.
To assist us in resolving this issue, we kindly ask you to submit an error report through the Samsung Members app on your device immediately after the issue is reproduced:
1. Open Samsung Members.
2. Navigate to One UI Beta Program > Beta Feedback.
3. Attach any relevant screenshots or screen recording/video (if possible).
4. Ensure "Send system log data" is checked, then submit the report.
Important: Please submit the report within 3 minutes of reproducing the issue for accurate log data collection.
We sincerely apologize for any inconvenience this may have caused and truly appreciate your contribution to improving the Beta experience.
Best regards,
One UI Beta Team
