Battery Drain
(Topic created: a month ago)
fishy98
Halo
Questions
Anyone else on the beta for the Watch 6 experiencing faster battery drain?
SpaceKvothe
Cosmic Ray
Questions
I've seen it suddenly gets in some mode when every 5-10 minutes it loses a 1%. This happens not all the time. I'm not sure the exact pattern though, trying to figure out. One thing I suspect helps: restart the watch.
USBetaModerator3
Beta Moderator
Questions
Hello,
Weโ€™re sorry for the inconvenience youโ€™re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members โ†’ One UI Beta Program โ†’ Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure โ€œSend system log dataโ€ is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
