SarahEBeth
- Mute
3 weeks ago in
Questions
My battery drains within 6 to 11 hours after a full charge. Does anyone have any tips, fixes, etc? I have the watch 8 40 mm classic. TIA for any help regarding this very annoying issue?
Makitel
- Mute
3 weeks ago in
Questions
1. Make sure you've downloaded the latest Watch Manger app from the Beta section.
2. Make sure all other apps are updated from the Galaxy Store.
3. Verify all the health sensors that are on are what you find necessary. (stats on blood oxygen level or 24 hour always on Heart Rate monitoring isn't always necessary and drains battery when on)
4. I set WiFi to auto and keep it off. It's not that necessary for an average user.
5. Turn off the watch. Charge it to 100. Turn on the watch. If the battery level is NOT 100, keep watch on and put back on the charger until it's 100.
TheReign
Cosmic Ray
- Mute
3 weeks ago in
Questions
Turn off screen always on, only allow the apps that you need to send notifications to your watch. Also there's a setting where you only get notifications on your watch if you're not on your phone, if it's not set that way then you will get notifications on your watch always. If all of your phone apps send notifications to your watch that is just burning up battery, for example I only allow phone calls, texts, Samsung health, and Facebook messenger (not Facebook in general) to send notifications to my watch. I charged my watch to 100% at 9am and it's now 8pm and I'm currently at 78% (watch 7).
