crackerjacksnr
Galaxy
- Mute
12-16-2024 03:21 PM in
Questions
So is is just me or did Samsung make the battery icon in the quick settings and notification panel way smaller? Why would they do that, it's even harder to read now then it was before. I hope you guys revert that change please
incconutwo
Galaxy
- Mute
12-16-2024 03:29 PM in
Questions
They did it so it's symmetric with the other icons.
crackerjacksnr
Galaxy
- Mute
12-16-2024 05:18 PM in
Questions
They should change the other icons then, its impossible to read basically
AlienX
Comet
- Mute
12-16-2024 04:49 PM in
Questions
Yeh all icon in status bar needs to bigger with bolder text. They made giant pills everywhere but the status bar has so tiny icon it doesn't sit well and also difficult to read.
crackerjacksnr
Galaxy
- Mute
Questions
Agree
Rotondo
Galaxy
- Mute
12-17-2024 11:43 PM in
Questions
Yes please Samsung can you make the icons on the status bar much bigger the battery and the signals everything seems so tiny hard to see!!
