Battery drain
(Topic created: 12-11-2024 07:42 AM)
Fjmg91
Cosmic Ray
Questions
Is anybody else experiencing battery drain with the Beta.
My battery goes down pretty quick since I installed the beta.
I know that could happen, but it's anyone else experiencing this?
Tmo1963
Halo
Questions
I think I found the culprit it's continuity of services when you look into device care in the details I just want to know if there's a way you can turn it off because the percentage of use is pretty high over 2% 3%
MGoBlue72
Cosmic Ray
Questions
Seeing a higher battery drain on my S24U than normal.
Tmo1963
Halo
Questions
Yes it's an app called continuity of services it burned 11% of my battery today
USBetaModerator3
Beta Moderator
Questions
Hello,
Thank you for your feedback on Battery drain (and Continuity of services).
To assist us in resolving this issue, we kindly ask you to submit an error report through the Samsung Members app on your device:
1. Open Samsung Members.
2. Navigate to One UI Beta Program > Beta Feedback.
3. Attach any relevant screenshots (if possible).
4. Ensure "Send system log data" is checked, then submit the report.
Important: Please submit the report within 15 minutes of reproducing the issue for accurate log data collection.
We sincerely apologize for any inconvenience this may have caused and truly appreciate your contribution to improving the Beta experience.
Best regards,
One UI Beta Team
