userzWTMM73eY5
- Mute
- Email to a Friend
β11-27-2021 05:13 PM in
Questions
On the lock screen it shows battery percentage is 0%. When i go into setting and turn on show battery status is shows up in navigation bar as 0% as well.
1 Reply
USBetaModerator
Beta Moderator
- Mute
- Email to a Friend
β11-29-2021 02:21 PM in
QuestionsHello @userzWTMM73eY5 ,
Thank you for your feedback. If you havenβt already, Please update Samsung members app to latest version from galaxy store and send us an error report immediately after experiencing the issue from the Samsung memberβs app -> Beta Feedback -> Error Reports to help us debug the issue. We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards,
One UI Beta Team
