Showing results forย
Search instead forย
Did you mean:ย
Problem
(Topic created: 06-02-2026 01:08 PM)
baconlover
Cosmic Ray
Questions
Using my galaxy buds 4 pro and turned the volume up and it locks my phone. Anybody else experiencing that issue?
USBetaModerator3
Beta Moderator
Questions
Hello,
Weโ€™re sorry for the inconvenience youโ€™re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members โ†’ One UI Beta Program โ†’ Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure โ€œSend system log dataโ€ is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
baconlover
Cosmic Ray
Questions
Tried to make a screen recording of it but after doing it several times it restarted my phone and I couldn't save the video.
