Showing results forย
Search instead forย
Did you mean:ย
Problem
(Topic created: 06-07-2026 04:37 PM)
baconlover
Cosmic Ray
Questions
Anyone else experiencing the volume issue with your ear buds? Can't take a screen recording of it because trying to do it several times results in your phone restarting. Big bug. Reported it too.
buckeye47
Galaxy
Questions
I use Tozo ear buds and notice the volume is inconsistent with the screen locked. Sometimes the volume increases and decreases at random times
baconlover
Cosmic Ray
Questions
I'm using the galaxy buds 4 pros and experiencing some glitching with mine from the beta
USBetaModerator3
Beta Moderator
Questions
Hello,
Weโ€™re sorry for the inconvenience youโ€™re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members โ†’ One UI Beta Program โ†’ Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure โ€œSend system log dataโ€ is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
