Add Flash Toggle to Expert RAW and Pro Camera Modes
(Topic created: 01-13-2026 08:02 AM)
Gio453
Suggestions
The Problem:
Currently, users of the S25 Ultra are unable to use the built-in flash when shooting in Expert RAW or Pro Mode. While these modes are intended for professional manual control, there are many scenarios (such as fill-flash for portraits or macro shots) where manual control over shutter speed and ISO needs to be paired with a flash.
Proposed Solution:
Flash Toggle: Add the standard Flash icon (Off/On/Auto) to the top bar of the Expert RAW and Pro Mode interfaces.
Fill Flash Sync: Ensure the flash can sync with manual shutter speeds (up to the hardware's sync speed limit).
Torch Mode: At the very least, allow the "Flash Always On" (Torch) setting to remain active while composing and capturing in these modes.
Why this matters:
The S25 Ultra is marketed as the ultimate "Pro" camera phone. Forcing users back to the "Photo" (Auto) mode just to use the flash defeats the purpose of having granular manual control. Adding this would bring the Galaxy camera closer to the functionality of a dedicated DSLR/Mirrorless system.
-CROW-
Supernova
Suggestions
Gio453
Suggestions
Whoops
USBetaModerator3
Beta Moderator
Suggestions
Hello,
Thank you for taking the time to share your feedback on Expert RAW and Camera modes.
We appreciate your suggestions and will forward them to the relevant team for review and consideration in future updates.
Your input is valuable and helps us enhance the overall One UI experience.
Thank you again for supporting the One UI Beta Program.
Regards,
One UI Beta Team
