zumaz
Cosmic Ray
- Mute
ā12-27-2024 03:40 PM in
Suggestions
I recently had a discord app update. After that the battery kept draining and it was hard to find the culprit as the app did not show up in the battery stats. I restarted and it still didn't fix it. Luckily I remembered there was a discord update and I reinstalled the app and it fixed itself.
Also, just yesterday, instacart also had an issue like this. I quickly reinstalled it and the problem fixed itself. Please allow us to see accurate battery stats even if the app is draining battery in the background. The app didn't show up in the app list which makes the problem invisible and a restart didn't fix it so the issue can be persistent?
youu
Black Hole
- Mute
ā12-28-2024 03:43 AM in
Suggestions
It's weird this beta requires us to uninstall and reinstall apps for them to work, this was never a problem last yr
zumaz
Cosmic Ray
- Mute
ā12-28-2024 09:04 AM in
Suggestions
Noticed this only with 2 apps as of now. I thought it was an issue with discord and didn't complain. But watching instacart invisibly drain my battery yesterday, I was sure it's a OneUI problem somehow somewhere.
![](/skins/images/580F7CF8EA7315A514AE52D55310C7E0/responsive_peak/images/icon_anonymous_message.png)
