Light/Dark mode color for Quick Panel
(Topic created: 09-21-2023 09:45 PM)
Suggestions
In One UI 5, light and dark mode quick panel was different colors, but now it is the same regardless of modes. Matching it with the mode like previous version would be nice! Also please make Device Control from quick panel to have Color Pallete applied as well.
ButtaBean_420
Neutron Star
Suggestions
I agree with you but once the stable version releases you will be able to change however you want using QuickStar in the Good Lock App
USBetaModerator2
Beta Moderator
Suggestions
Hello,
Thank you very much for your suggestion.
Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept.
We appreciate your contribution to the beta program.
Regards,
One UI Beta Team
