PLEASE FIX BATTERY DRAIN ASAP
(Topic created: 03-17-2026 11:14 AM)
blackborns
Suggestions
After one ui 8.5 beta 7 update, battery drains really fast, only getting about 4hrs SOT on the s25 ultra, compared to before with 7-8hrs SOT. needed to charge phone now twice a day. Please fix this asap Samsung or do an emergency update to fix battery drain
Suggestions
Use this app after every update and once a week .the module needed is app booster
https://apps.samsung.com/appquery/appDetail.as?appId=com.android.samsung.utilityapp. i dont have any issue after using it.
USBetaModerator3
Beta Moderator
Suggestions
Hello,
Weโ€™re sorry for the inconvenience youโ€™re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members โ†’ One UI Beta Program โ†’ Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure โ€œSend system log dataโ€ is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
