SammyS23
Galaxy
- Mute
09-13-2023 03:15 PM in
Suggestions
It has been less reliable on beta and would like to see it fixed. I hope to see some improvements and optimization. For example, network switching can be slow and could take up to 20s to switch from wifi to 5G. Also have noticed slower speeds.
Brucyjay
Halo
- Mute
09-13-2023 06:51 PM in
Suggestions
Slow switching from roaming back to tmobile too.
USBetaModerator 2
Beta Moderator
- Mute
09-15-2023 08:19 AM in
SuggestionsHello,
Thank you very much for your suggestion.
Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept.
We appreciate your contribution to the beta program.
Regards,
One UI Beta Team
userMl3j4JZZt7
- Mute
09-24-2023 02:34 PM in
Suggestions
Unlocked on T Mobile here. Running latest beta on S23U. If I turn off Wi-Fi, my signal bars remain full (I can see the tower from here) but the 5G icon never comes on. If I disable 5G service in the network settings, it connects to LTE+ and works fine. If I leave 5G enabled, turn off Wi-Fi (stuck here with full bars and no connection/5G icon), toggle airplane mode on and then off ,then it'll connect to 5G.
