Edge panel long-press toggle
(Topic created: 08-25-2026 02:05 PM)
Mujibar
Honored Contributor
Tips
You can now turn off the edge panel long-press that activates AI Select. Settings > display > edge panels.
Robin621k
Honored Contributor
Tips
OMG, good things come to those who ask!
Mujibar
Honored Contributor
Tips
I figured you'd like this one.
Robin621k
Honored Contributor
Tips
It was one of my first requests!
Mujibar
Honored Contributor
Tips
I'm aware ๐Ÿ˜
Y0u
Honored Contributor
Tips
I though it was to who wait
Robin621k
Honored Contributor
Tips
Sometimes it's just ask!
requa
Sun
Tips
Thanks, @Mujibar ! This restored the ability to use Edge Panels without figuring out my fat fingers. I guess I should say "Edge Panel," because the compass in the Tools panel is the only one I use and missed. OK, maybe the ruler and surface level in the Tools panel, occasionally. ๐Ÿ˜
Dan
Galaxy S26 SM-S942U1 on Xfinity Mobile
Mujibar
Honored Contributor
Tips
You're welcome, @requa! We can thank Android Authority for writing about it. That's how I found out because, of course, this wasn't in the changelog.
https://www.androidauthority.com/samsung-one-ui-9-beta-6-edge-panel-ai-select-toggle-3702756/
requa
Sun
Tips
The Edge Panel is really more of a cute remnant of the old Edge series phones with the curved screen, but I'll take it. What I'd really like to see is the same functionality of the Tools Edge Panel in a Home Screen Widget, possibly showing a 1*1 compass like the one that shows in Google Maps until clicked.  Dang. I wish I'd thought of that months ago to suggest it for OneUI 9.
Dan
