S21+ screen timeout doesn't work after panel replacement
(Topic created: 07-20-2021 09:47 AM)
userK1bmAAuGW6
Galaxy S21
My screen failed in my S21+ and the panel was replaced under warranty, however since the new panel was installed my auto screen timeout isnt working. The setting is set to auto timeout at 30 seconds. After 30 seconds the screen dims some but never goes completely dark to the lock screen causing my battery to drain. Any ideas?
cmickie1225
Galaxy S21
Mine has been doing that as well after getting the charging port replaced. Now I have to physically tap it to shut of the screen. Like **bleep**?
userK1bmAAuGW6
Galaxy S21
Same, I have to press the lock button every time I use it
TheGalaxy
Black Hole
Galaxy S21
At the time when you made that settings with the old screen, there are hardware communications between your phone and your old screen. Now that you changed the screen those communications are lost.
Try clear the e cache of not the data of UI home
If not wipe cache partition from recovery mode
If not backup and factory reset
userK1bmAAuGW6
Galaxy S21
Can you tell me the steps to do those 2 things?
TheGalaxy
Black Hole
Galaxy S21
Settings >apps>show system app>one ui home
