Streaming problem on QN65Q800T
(Topic created: 03-01-2024 11:57 AM)
Jrkoesterer
QLED and The Frame
Peacock and Disney don't work, everything looks correct but won't play content (QN65Q800T)
GaryB82
Epic Samsung Care Ambassador
QLED and The Frame
Is it giving you a Error code
If you've found my post to be helpful, Please like the post.
If my response resolved your issue, please press the Like and ✓ to Accept as Solution button.
Jrkoesterer
QLED and The Frame
No error codes , just spinning circle
GaryB82
QLED and The Frame
To solve problem go to settings on TV and clear the cache for the Peacock and Disney app. This should resolve the issue.
Open TV settings and Scroll down to Support and click Self Diagnosis then click TV Device Manager then scroll to the right and Under Manage Storage click Show App list and then scroll over to the Disney app and select View More and select Clear Cache and do the same on the Peacock App
Jrkoesterer
QLED and The Frame
Cleared data with no success
getting “Sorry something went wrong. Please try again later”
GaryB82
QLED and The Frame
You want to Clear the Cache not Data and if that doesn't work I would suggest Uninstalling the App and reinstall it too see if that works
Jrkoesterer
QLED and The Frame
Can’t uninstall app, OS won’t allow
GaryB82
QLED and The Frame
Strange I was able to uninstall both of them on mine
Jrkoesterer
QLED and The Frame
I have a QN65Q800TAFXZA if that helps
Jrkoesterer
QLED and The Frame
For reference I can make this work by going through Mac mini, this seems like Samsung software error.
