Heating up/Battery drain
(Topic created: 10-09-2023 01:13 PM)
JesterPizzle
Comet
Discussions
I just reported these issues to the Beta feedback. Since updating to Beta 6 my phone is getting hotter than usual while playing games and watching YouTube at the same time. My battery also has an abnormal amount of drainage. I took my phone off the charger with 100% at 5am and it's now 1pm at 36%. I'm using my phone like I usually do and would normally have between 70-75% left by this time. I noticed this yesterday but thought that I'd give it another day to maybe adjust to the update but nothing is better.
joelor
Halo
Discussions
Mine is warm also, battery drains alot faster too.
wackywood82
Cosmic Ray
Discussions
Yeah same here .. battery seems to have gotten worse... I hope they do something to correct the issue for the final release or even another beta
Mike-B
Comet
Discussions
Did you boot into recovery mode and then clear the cache partition after the update? It's seriously one of the best things you can do to avoid most problems!
JesterPizzle
Comet
Discussions
I'll give it a try and let you know.
JesterPizzle
Comet
Discussions
Tried booting into recovery mode and then cleared the cache partition. Still the same. Maybe after stable release and apps update for it, it'll get better 🤷
Mike-B
Comet
Discussions
I would say boot back into recovery mode again and clear the cache partition one more time and then when it puts you back to the list of selections instead of using reboot use Repair Apps and see if that helps anything because I personally am not having any battery problems. In the very beginning there usually is a lot of battery usage but that's just until the operating system figures out which apps you use the most daily and then puts all of the other stuff to sleep thereby causing less battery usage. Edit: Also, make sure all of your apps in BOTH the Google play store AND the Samsung Store are up to date.
46m3csl
Comet
Discussions
Same having the battery drain much faster
USBetaModerator2
Beta Moderator
Discussions
Hello,
Thank you for your feedback.
Please use the latest Samsung Members app to submit an error report (Samusng Members One UI Beta Program Beta Feedback Error Report.
- To provide UX or UI-related feedback, such as usability or feature suggestions, select "Beta community Suggestions" in the Beta recruitment notice of Samsung Members app.
We appreciate your contribution to the Beta Program.
Regards,
One UI Beta Team
