Samsung LED View Cover issues.
(Topic created: 08-28-2022 06:10 PM)
kosovo275
Discussions
I purchased the LED case a week ago, and everything initially worked perfectly. The services were working. I could male my own led icons, etc.
Since installing the one ui beta though, all lf that functionality is completely broken and not functioning at all. The only error message im receiving is "This content isn't compatible with your phone's operating system. (9909)" each time i try to open the accessories settings. Anybody else have this issue?
karang
Discussions
Hi All,
I have update my phone with latest security update and suddenly my led cover have stopped working g it was working fine before and even I cannot find the app led cover in my mobile. Is anyone facing same issue?
SuperBoop
Sun
Discussions
It's an actual app samsung has that uses a chip or something to recognize when u close ur s view cover. So make sure in setting go to Apps and search for LED cover. Make sure it's installed and enabled. If not, I guess factory reset your phone. But make sure to try other methods other than what I've listed before resetting ur phone.
Keep in mind it could be the Cover case too.
