Significant battery drain
(Topic created: 10-13-2022 09:27 PM)
userNSZ3NUsTsH
Discussions
I have noticed a significant battery drain with beta version zvlh going from a 100% full charge down to 56% in 13 hours with moderate use I'm not sure if it's specifically tied to the beta version or if there's something that I could try to slow down battery drain power saving options don't feel like their operating
please advise I'm sorry if I posted this in the wrong area I'm brand new to the beta program all of 24 hours maybe so I'm still getting the hang of where things go
Dalejr33
Discussions
I'm having the same problem. My phone is dying with around 2 hours of screen on time. It's terrible!
Vince82
Galaxy
Discussions
I have the same issue plus my phone gets a bit hot when using it for a little while like 2 to 5 minutes of use
Archer818
Halo
Discussions
Have you tried clearing the cache portion and repairing apps in the recovery menu? I still have the same battery on my ultra on the beta.
userNSZ3NUsTsH
Discussions
No I have not tried that I'll go into recovery mode right now and clear the cache and I'll report back soon
JeremyP14
Halo
Discussions
ZVIH seems to be the most battery friendly beta for me. I had 6hr SOT with WQHD and 120hz. When I joined the Beta Program it seemed like my device had to "relearn" my habits to optimize battery performance. Not sure if there's truth to that, but it acted similar to when I got the device new.
Also, 13hrs and 44% battery drain does not sound bad at all, honestly. What's your SOT and settings?
userNSZ3NUsTsH
Discussions
My screen on time is 1 hour 25 minutes with resolution set to the highest and adaptive smoothness
My device started at 100% and has been off the charger for 5 hours and 13 minutes & currently at 81% as of this moment and I did briefly go into recovery mode and cleared the cache so I think my device is relearning my usage pattern
userNSZ3NUsTsH
Discussions
I did put the majority of my phone with the exception of critical apps into deep sleep mode which appears to be helping the battery drain
