Using Smart Oven with Alexa
(Topic created: 01-10-2025 07:53 AM)
octoplayer
Kitchen and Family Hub
Hi,
Just got a Dual oven Series 5. I can control / monitor it via the App, and I have linked the app to my Alexa skills.
However, when I ask Alexa to turn off or set the oven it says "I am not quite sure what went wrong".
If I try a routine, the only action options are turn turn the Oven light on or off, or set brightness (Bright or off), which do nothing.
Am I missing something, or is Alexa not really supported?
Thanks
