Battery Drain Beta 4
(Topic created: 11-04-2021 08:26 PM)
CidKid
Questions
Anyone else having issues with the battery draining faster than normal since Beta 4 update?  Any solutions?
user365170tdJ15
Honored Contributor
Questions
Only very slightly less. It's not like with Android 11 UI 3, but it almost is.
Questions
I did and found out it's Facebook... I uninstalled it yesterday and one charge gave me 8 hours sot on LTE(6am-11pm)... I installed it back on today....3 hours sot before I had to recharge. (6am-5pm)
USBetaModerator
Beta Moderator
Questions
Hello @CidKid ,
Thank you for your feedback. If you haven’t already, Please update Samsung members app to latest version from galaxy store and send us an error report immediately after experiencing the issue from the Samsung member’s app -> Beta Feedback -> Error Reports to help us debug the issue. We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards,
One UI Beta Team
user_ams007
Planetary Samsung Care Ambassador
Questions
Try installing the Samsung Good guardian's app and then click on the battery guardian and also the Galaxy application booster and you should see a difference
