Battery Drain
(Topic created: 04-21-2026 12:29 PM)
HonuPDX
Questions
New beta seems to drain battery, anyone else?
jimmydogfish
Questions
No, actually I have experienced better battery life. The 2nd beta had really bad battery life for me though.
benYehoshuwa
Cosmic Ray
Questions
I have experienced faster drain as well. But its supported by the faster charging im experiencing so it seems to balance out.
jimmydogfish
Questions
Faster charging? What model do you have?
ISurfTooMuch
Cosmic Ray
Questions
Yeah, I'm noticing faster battery drain as well. In fact, I was just checking to see if anyone else is seeing it.
kbrncito
Galaxy
Questions
Same here, but it is expected from betas... it got a bit better with the last update though
USBetaModerator3
Beta Moderator
Questions
Hello,
We’re sorry for the inconvenience you’re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members → One UI Beta Program → Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure “Send system log data” is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
