Battery drain since installing ui9
(Topic created: a week ago)
Asetech2
Questions
Has anybody experiencing battery drain since installing you UI 9?
Pianodude58
Honored Contributor
Questions
Please ensure that all communications pertaining to the Beta program are directed to the designated Beta Community.
Asetech2
Questions
Ok
CJ32323
Questions
Yeah it's pretty bad on my watch.
USBetaModerator3
Beta Moderator
Questions
Hello,
Weโ€™re sorry for the inconvenience youโ€™re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members โ†’ One UI Beta Program โ†’ Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure โ€œSend system log dataโ€ is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
