Showing results forย
Search instead forย
Did you mean:ย
Battery draining
(Topic created: 05-11-2026 04:41 AM)
Asetech2
Questions
I have a Galaxy s24 ultra that had a good battery life. Since the update the battery seems to be draining quite quickly maybe I'll get a day out of it. Using apps and so forth causes the drain a lot quicker. Has anybody found this issue and away to rectify it?
1 Reply
USBetaModerator3
Beta Moderator
Questions
Hello,
Weโ€™re sorry for the inconvenience youโ€™re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members โ†’ One UI Beta Program โ†’ Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure โ€œSend system log dataโ€ is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
