Showing results forย
Search instead forย
Did you mean:ย
Battery drain
(Topic created: 3 weeks ago)
deviceholder
Questions
I have used my S24 Ultra since I pre-ordered it almost two years and ten months ago, but before the beta update, my battery was heavily draining.
RedOregon
Sun
Questions
Is this a question?
tspry_aviation
Cosmic Ray
Questions
Funny bc the 9 beta update fixed the 8 stable battery drain issues i had
kbrncito
Galaxy
Questions
For me it's the opposite, my battery life has been crappy with the beta, but I'm waiting patiently for the release of stable and I will do a factory reset this time. To start fresh again
tspry_aviation
Cosmic Ray
Questions
Only issues i am having related to power is super fast charging with flagship anker pd power bricks it wont stay charging. It will alternate between charging and not charging for no reason.
