Continuity Service Battery Drain
(Topic created: 12-12-2024 04:14 PM)
Questions
Does anyone else have an issue wi5h battery drain? When I check the battery usage by app the continuity service uses almost 7% when I haven't even used it! I don't know why it's doing that when I haven't even used it that day. Also it's always running in background it appears. Drains battery insanely fast, Samsung please fix this.
Sidde
Questions
I removed all the permissions for the app and that stopped the battery from draining.
OddyNuf
Galaxy
Questions
I've noticed that is usually at top of the list for battery also. But today only shows 1% for me. Although it shows almost 5 hours background use with 121 wake ups
Questions
It's a lot of wakeups and it makes my phone hot when im not even using it. Hopefully Samsung sees this post
OddyNuf
Galaxy
Questions
Yea it is a lot. Was trying to figure out what exactly is using that service.
Questions
It's a huge problem here as well, I sent feedback about the bug and encourage others to do the same
Y0u
Honored Contributor
Questions
I would report this issue to amsung so they can look into it
Sidde
Questions
Questions
As of beta 2 it seems to have been fixed but this worked for me until beta 2. Im going to give the permissions back and see
USBetaModerator3
Beta Moderator
Questions
Hello,
Thank you for your feedback on Battery draining issue.
We appreciate your contribution to the Beta community.
Regards,
One UI Beta Team
