Battery drain
(Topic created: 12-11-2024 07:56 AM)
Tmo1963
Halo
Questions
Hello is there any way that continuity of services can be turned off when checking out device care and under details that was the number one app that uses battery maybe 3% or more
USBetaModerator3
Beta Moderator
Questions
Hello @Tmo1963,
You can reject permission for Continuity of services in your system app (Settings > app > Show system apps > turn off all permissions).
Regards,
One UI Beta Team
Questions
I'm having severe wakeup & drain issues with the app as well. I submitted Feedback with a system log and advise all others to do the same. 1734102166878.jpg
Y0u
Honored Contributor
Questions
Have you reported the issue to samsung, and did you clear the cache partition
