| Custom List Message Item |
Will we be getting an update to HomeUp so it can work on 8.5 because right now I can even use it? View Post I think you can leave as easily as you joined. It looks like 1 click a few windows back. I knew some... View Post |
Where is the chat settings for Samsung messaging on the S25 ultra. New to Beta View Post |
Is anyone having issues making calls. I have tried with wifi and cellular network. I've rebooted and cleared cache. I can make phone calls on... View Post Try going into Settings- General Management- Reset- Reset Mobile Nework Settings View Post |
How do enable RCS chat on secure folder. Its set as default app. View Post If you have set it up outside the secure folder, you will need to do the same steps again when you p... View Post |
Anyone having service issues? View Post Try going into Settings- General Management- Reset- Reset Mobile Nework Settings View Post |
Eliminaron la dual camara de video, ya ni aparece View Post Hello, Thank you for sharing this valuable tip with the community! Your contribution is incredibly h... View Post |
Does anyone know what's going on with Now Brief? When using the UI 8.5 Beta program, it doesn't give me any information when I click on it... View Post Hello, Thank you very much for sharing your feedback. To help us investigate further, please submit ... View Post |
System sound, apps, even YouTube Music audio works. Youtube sound does not. I cleared cache and data, reinstalled YouTube, and restarted phone and... View Post Hello, Thank you very much for sharing your feedback. To help us investigate further, please submit ... View Post |
Is it just me not getting any post reply notifications? On the beta section only. View Post Hello, Thank you for taking the time to share your feedback. We appreciate your suggestions and will... View Post |
How do I get back to one ui8 my new hearing aids aren't working good wit the beta before it would tell me in smart switch but it didn't for... View Post Hello, Thank you for taking the time to share your feedback. Your input plays an important role in h... View Post |
Ever since beta 2 update I've been experiencing freezes and random reboots. Freezes I've got to use button combo to fix. Have done multiple... View Post Hello, Thank you very much for sharing your feedback. To help us investigate further, please submit ... View Post |
SInce the iodine i am not able to conn3ct ky external monitor anymore. Anyone else having same issue or have recommendations? View Post Hello, Thank you very much for sharing your feedback. To help us investigate further, please submit ... View Post |
I just updated to the 2nd beta and I still do not have the dual recording showing. I checked and my camera assistant is stuck on v 4.0.00.6 ... View Post Hello, Thank you for sharing this valuable tip with the community! Your contribution is incredibly h... View Post |
I was told we were getting like emojis but idk haven't figured out where they are or can't use them ?? View Post Hello, Thank you for taking the time to share your feedback. Your input plays an important role in h... View Post |
My wallpapers keep changing itself View Post Hello, Thank you very much for sharing your feedback. To help us investigate further, please submit ... View Post |
I'm not interested in seeing every minute the battery percentage how do I turn it off? View Post Hello, Thank you for your feedback. You can customize your battery percentage via QuickStar, which m... View Post |
How to use daul record video on 25ultra after the 8.5 update its ... the change log said it was in camera assist app settings but I dont see it View Post Hello, Thank you for sharing this valuable tip with the community! Your contribution is incredibly h... View Post |
Can someone fix or figure out how to have the Media Controller on the Galxy Watch 6 Classic and Galaxy Watch Ultra actually work again with the... View Post Hello, Thank you very much for sharing your feedback. To help us investigate further, please submit ... View Post |
Is anyone having issues getting Google Play Store to respond since the update? I can't go in and use my play points. It just spins and spins. ... View Post Hello, Thank you very much for sharing your feedback. To help us investigate further, please submit ... View Post |
Initial reboot after beta 2 install went ok. Later in the day I restart the phone and after the home screen appeared I noticed my widgets were... View Post Hello, Thank you very much for sharing your feedback. Once your error report is reviewed; we will sh... View Post |
I tried to test the Expert Raw app after updating to One UI 8.5 Beta 2 and it rendered it unusable. I even tried the APK... View Post Same here when you open Expert Raw it says a New Version is available but when you tap on it there i... View Post |
I am unable to view files on my Samsung external drive when connected to my s25 ultra. Samsung magician shows it being connected and readable but... View Post Hello, Thank you very much for sharing your feedback. To help us investigate further, please submit ... View Post |
I've been having this issue since yesterday, since I formatted my device. It was one Beta 1. Now I'm ok Beta 2 and it's still... View Post Hello, Thank you very much for sharing your feedback. To help us investigate further, please submit ... View Post |
