Help! latest Beta locked up my S23 phone (wont power off or restart from screen menu)
(Topic created: 10-24-2023 11:08 AM)
prabs
Questions
Help! latest Beta locked up my S23 phone (cannot power off or restart). Any ideas?
edit: Just figured out hard reboot by holding power/vol- until reboot. that took care of it. The on-screen "power off/restart" would not get past the hard lock that happened (black screen with only samsung pay swipe bar visible)
ucancwhatic
Red Giant
Questions
Was going to recommend a hard reboot. Glad you figured it out
Ayrus
Questions
Also, if you have Good lock installed - uninstall it, I think it is not compatible with the beta. I had a similar issue and the phone stopped working, could only get to Samsung wallet screen.
prabs
Questions
exactly what happened with mine. hard reboot got past it. i do have goodlock installed, leaving it for now as i hear stable might be coming out soon.
thanks guys.
user_ams007
Planetary Samsung Care Ambassador
Questions
The Samsung Good Lock application works with the Beta firmware, except for a few modules that are in Good Lock
user_ams007
Questions
Try clearing the cache partition from your phone, this seems to help with the problems that you are experiencing
USBetaModerator2
Beta Moderator
Questions
Hello,
Thank you for your feedback.
If you have any other issues, please use the latest Samsung Members app to submit an error report (Samsung Members One UI Beta Program Beta Feedback Error Report.
- To provide UX or UI-related feedback, such as usability or feature suggestions, select "Beta community Suggestions" in the Beta recruitment notice of Samsung Members app.
We appreciate your contribution to the Beta Program.
Regards,
One UI Beta Team
