Problem Removing Beta
(Topic created: 08-05-2025 01:29 PM)
Rickfadvent
Questions
I requested to be on the OneUI 8 beta. I'm on it and used approved methods to remove it but it comes back. How can I just revert to the stable version?
Members_44RwkPy
Cosmic Ray
Questions
Did you use smart switch on your computer with your phone plugged in?
Y0u
Honored Contributor
Questions
Yes unroll from the beta program than use smartswitch to roll back, BUT before you do backup your data as it will reset your phone if you do
USBetaModerator3
Beta Moderator
Questions
Hello,
Thank you for your feedback.
To leave the Beta test,
1. Move to the detail page on the participated Beta test
2. If you push the menu which is on right supper side of detail page, it's possible to do a leaving.
3. When submitting the survey, the canceling process is completed.
Please note that once you leave Beta, you won't be receiving Beta updates until the official release.
Make sure all your data is backed up before rolling back to previous official version via Smart Switch.
We appreciate your contribution to Beta program.
Regards,
One UI Beta Team
