Wireless charging does not work
(Topic created: 10-06-2023 09:29 PM)
Hsadi
Questions
Hi,
I have an samsung galaxy s22. Before I updated to android 14 beta my device used to charge on wireless charging.
The issue now after I updated to Android 14 is that my device does not support wireless charging. It does charge normally via USB though.
I use the following wireless charger:
Please do note that before upgrading to android 14 my device used to successfully charge using wireless charging
Members_zQI73FG
Questions
Yes, I also experienced the problem of not charging with Samsung P2400 wireless charger
notforhire
Honored Contributor
Questions
must be something particular to that charger...my wireless charging still works after the beta
Chef31684
Red Giant
Questions
Wireless charging still working fine for me
Hsadi
Questions
Which wireless chargers do you all use?
Kenh50S22U
Halo
Questions
Samsung EP-P3105
USBetaModerator2
Beta Moderator
Questions
Hello,
Thank you for your feedback.
Please use the latest Samsung Members app to submit an error report (Samusng Members One UI Beta Program Beta Feedback Error Report.
- To provide UX or UI-related feedback, such as usability or feature suggestions, select "Beta community Suggestions" in the Beta recruitment notice of Samsung Members app.
We appreciate your contribution to the Beta Program.
Regards,
One UI Beta Team
