Showing results forĀ
Search instead forĀ
Did you mean:Ā
Edge Lighting - Black Hole (Ring Notification Light)
(Topic created: 09-16-2021 08:55 AM)
Saifu
Cosmic Ray
Suggestions
This was a edge lighting effect that was available on my S10e when installing the Edge Lighting + app from the Galaxy Store. It was a amazing and subtle edge lighting effect. I really think that Samsung should bring back this effect as it was a simple ring light that would occur around the camera cutout when you got a notification. It sort of reminds me of the notification LED I used to have on my S7 Edge. If anyone is wondering how it looks, it is exactly like the effect you get when you open your front selfie camera. Samsung please bring it back!
iiDark
Galaxy
Suggestions
Yes please. I love this. I had no idea it was a thing!
jerkwad
Suggestions
Yes! Please add this!
boston503
Nebula
Suggestions
Its still in the settings but its hidden well
Saifu
Cosmic Ray
Suggestions
Really? Where exactly because I don't see the option?
USBetaModerator
Beta Moderator
Suggestions
Hello @Saifu ,
One UI 4 uses same lightning effect for privacy controls to let you know if your camera is being used which may cause some confusion if used for all notification. We will still send suggestions to usability team for review to see if they can possibly implement a specific color for privacy and different one for app notifications.
Regards
One UI Beta Team.
Saifu
Cosmic Ray
Suggestions
Oh I understand, but please do consider giving it as an option even if it changes color for different apps or can stay white. If someone feels confused by it they can always turn it off. šŸ™‚
