d4raxx
Cosmic Ray
- Mute
- Email to a Friend
β10-03-2021 10:07 PM in
Suggestions
fix navigation bar gesture home animation sometimes being laggy and looking like frames going very low when it should always be a stable 120 fps on a 120hz screen. This could also be said the same for the quick panel when you swipe on top of screen and down twice to bring quick panel down and yet it also looks laggy as if im on 60hz or something so a fix for that would be good. Also if possible some apps like literally the Samsung member app itself lol, samsung cloud, settings app, or other apps having a problem of having no open animation at all sometimes when animator duration scale is clearly turned on and not off. These being fixed would always be a smooth experience if fixed.
Another suggestion is for even much better battery saving. I found out on always on display it shows that it is refreshing at 60 fps all the time. It would be better or nice to have an option to set the refresh rate to 30 or lower instead of 60 when on always on display. Also if possible and not in a too laggy way when switching, make an option to be at 30hz idle or since ive heard s21+ refreshes a minimum at 48 fps, make the idle go to 48 fps instead of 60 and same for always on display or simply just 30 if simply possible. This would save battery even much better on always on display or being idle/afk from the phone screen.
1 Reply
USBetaModerator
Beta Moderator
- Mute
- Email to a Friend
β10-04-2021 01:51 PM in
SuggestionsHello @d4raxx ,
Thank you for your feedback. If you havenβt already, Please update Samsung members app to latest version from galaxy store and send us an error report immediately after experiencing the issue from the Samsung memberβs app -> Beta Feedback -> Error Reports to help us debug the issue. We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards,
One UI Beta Team
