Need help with connecting my new S Pen
(Topic created: 07-22-2021 01:29 AM)
jwflooman
Galaxy Note Phones
Please help me figure how to program my new s pen.
LongHiker
Samsung Care Ambassador
Galaxy Note Phones
@jwflooman try this:
  1. Insert the new stylus into the S Pen storage/connection slot.
  2. Slide down from the top of your screen to access the Quick Start menu. Then, slide down again to display more options.
  3. Locate the "S Pen air actions" icon. If it is highlighted/on, click it to turn it off.
  4. Click the "S Pen air actions" icon again to turn it on. You will get a prompt at the bottom of the screen.
  5. Select "Connect new S Pen." Please note that removing the S Pen from the storage/connection slot will interrupt the pairing process.
Pmarsh306
Galaxy Note Phones
I have the same issue with s pen not connecting. I've tried everything and nothing works
