Battery Drain
(Topic created: 03-10-2025 10:21 AM)
userlQcCM1wRc8
Black Hole
Discussions
Sent the following to Samsung. Anyone else experiencing excessive battery usage?
[Power/Battery/Charging]
Subject: Battery Drain Issue on S24U with Beta 4 and Recent Hot Fix
Dear Support Team,
I am reaching out regarding a significant battery drain issue Iโ€™ve been experiencing on my Galaxy S24 Ultra while using Beta 4 and the most recent Hot Fix.
As shown in the attached screenshot, the battery dropped by 35% within just 4 hours and 30 minutes of fairly light usage. The performance profile is set to "Light," and Adaptive Battery is enabled.
To address the issue, I have:
- Disabled Adaptive Battery.
- Enabled Power Saving Mode with the processor limited to 70%.
- Kept the Light Performance Profile engaged.
Despite these adjustments, the battery consumption remains excessive. For instance, the logs indicate that the battery dropped from 71% to 66% while the screen was off for a period of time.
As a next step, I plan to reboot the device and clear the partition cache. However, I would appreciate your guidance on resolving the issue effectively l.
Thank you.
03/10, 12:14 PM
Thanks for your feedback, which will be used to help improve our software. As the software is updated, we'll let you know about fixes and improvements.
03/10, 12:14 PM
incconutwo
Galaxy
Discussions
Yes, I have it. Resetting the phone will see if it fixes the problem.
userlQcCM1wRc8
Black Hole
Discussions
Full reset? If you do this, please let me know if the situation you are having is resolved?
Also, the process you used.
Will Smart Switch reinstate all the settings you had.
The_Chief
Sun
Discussions
Resetting the phone only removes all user data and apps: a factory reset does not touch the /system partition and has no effect on the operating system! It's waste of time and effort setting it up again.
userlQcCM1wRc8
Black Hole
Discussions
Thank you!
Phoneybologna
Galaxy
Discussions
My battery is the best I've ever experienced since beta 4 update.
DaleNet
Nebula
Discussions
No problems with mine.
Ryanoutdoors
Nebula
Discussions
Battery life is amazing
userlQcCM1wRc8
Black Hole
Discussions
Define amazing? Settings?
Ryanoutdoors
Nebula
Discussions
amazing. adjective. : causing amazement, great wonder, or surprise.
