Q900 won’t turn on
(Topic created: 11-16-2024 07:59 PM)
Marv1
LED and OLED TVs
Hi. We purchased the samsung TV model QN75Q900TSFXZA less than 3 years ago. We started having issues recently with blue vertical  lines  almost in the center of the screen. Today all of sudden the tv turned off and it won’t turn on. Very disappointed especially this is our second Samsung tv with major issues. Any advice would be appreciated!  Thank you
Samsung_Moderator
LED and OLED TVs
Hello@Marv1! Thank you for reaching out! This is something that will require service. Depending on your warranty you will have a few options.
- If your unit was recently purchased, you can check with your retailer on their return/exchange processes.
- If you have an extended warranty you can reach out to them to have service set up.
- If you're within the one year warranty, you can Private message me or one of our moderators or you can call in directly at 1-800- 726-7864 with your full model and serial number to have service setup
- If you're OUT of warranty, you can use this link below to find a service center in your area.
https://www.samsung.com/us/support/service/locations/
Diaboyos
Honored Contributor
LED and OLED TVs
Is it still under warranty? Unfortunately, if it's out of warranty the cost to repair or replace it will be up to you.
Samsung_Moderator
LED and OLED TVs
