- Mute
ā09-15-2021 07:15 AM in
Questions- Mark as New
- Mute
ā09-15-2021 07:30 AM in
- Mute
ā09-15-2021 07:42 AM in
- Mute
ā09-15-2021 07:39 AM in
- Mute
- Mute
ā09-15-2021 08:06 AM in
- Mute
ā09-16-2021 07:47 AM in
QuestionsHello @Ruki ,
Battery consumption may be a little higher after a software update. Give it a day or two and if it doesn't improve, Please send us an error report from the Samsung memberās app -> Beta Feedback -> Error Reports to help us debug the issue. We apologize for the inconvenience and appreciate your contribution to the beta program.
You may also try to clear cache of the device by following below steps.
- Turn off the device.
- Press and hold the Volume Up key and the Side key.
- When the Android logo displays, release both keys.
- An 'Installing system update' message may show briefly before the Android Recovery menu options appear.
- Press the Volume down key several times to highlight Wipe cache partition.
- Press Side key to select.
- Press the Volume down key to highlight Yes, then press the Side key to select.
- When the process is complete, Reboot system now is highlighted.
- Press the Side key to restart the device.
Regards,
One UI Beta Team
- Mute
ā09-16-2021 08:09 AM in
Questions
