Showing results forΒ
Search instead forΒ
Did you mean:Β
Battery drain
(Topic created: 10-18-2021 03:34 AM)
Questions
After the second beta update my battery life terrible, after some research I find out what app was causing that, sadly I can't clean the cache of this app and I already restart my phone and nothing changes, someone knows what to do?
Thank so much community!
Btw the app name "Google play Services"
YoDiggityDad
Cosmic Ray
Questions
I've been seeing the same thing.
Dingodown
Comet
Questions
Wow. That's quite a bit. Have you tried putting all other google related apps to sleep to see if that helps? Sometimes, it's not one program but several tied into it.
Questions
I already try that, seems that nothing changes, but thank you for the help
Questions
"Google play service "
Questions
Thank you I will check that. The app name is "Google play services"
USBetaModerator
Beta Moderator
Questions
Hello @LucasCompatangelo ,
Please let us know why you are unable to clear cache of the app. As a side note, Clearing data would lose your data but cache is just for faster access and will built up soon by the app after a few uses
Regards
One UI Beta Team
likearaptor
Cosmic Ray
Questions
Google play services for me seems normal on beta 2, running around 6-8% of battery each day, I wish it would be less, but I think this is the best it's going to get with location tracking and a few other Google services turned on
TheNewsHQ
Comet
Questions
Since when will clearing cache help with Battery not draining?
Questions
Clearing system cache can get rid of corrupt files and allow the software to 'recorrect' itself, and usually helps with misbehaving apps or services that may drain battery.
