Showing results forĀ
Search instead forĀ
Did you mean:Ā
Tuesday Battery Drain Day?
(Topic created: 10-04-2021 03:49 PM)
bigbad614
Nebula
Questions
Anyone else experiencing more battery drain on more specific days, than others?
My battery has been half as good on Tuesdays...
What about you?
user751201tmO21
Honored Contributor
Questions
For me, it drains consistently ... moreso during the beta than previous stable Android 11 UI 3.1 (obviously) ... "day" doesn't matter.
Maybe on Tuesdays, you're doing more work on the phone?
bigbad614
Nebula
Questions
Nah, not really anymore than usual. My average screen on time is 6hrs.
Battery life is definitely not as good as 11, as you said. Tolerable overall, except for Tuesdays. All I have is my daily drain noted. No other proof. No biggie, I guess. Was just curious if others noticed a worse "day" vs other days.
never-reven
Nebula
Questions
I hadn't noticed drain until last week. Super annoying constantly draining. I don't notice drain on specific days but I notice drain around 3-5 pm. 90% down to 50% everyday.
USBetaModerator
Beta Moderator
Questions
Hello @bigbad614 ,
Please navigate to settings -> battery  and device care -> battery and swipe left on the graph. This should show your usage for last week. Clicking on date should provide apps that use most battery on a certain date.  You can compare top app for batter y consumption on Tuesday with usage of battery for same app on a different day. This may help narrow down the cause. It could be something as simple as having additional call in meeting on the day to a extra workout etc.
Regards
One UI Beta Team
